Water heater thermostat | on ElectriciansForums
Discuss Water heater thermostat in the UK Electrical Forum area at ElectriciansForums.net
WallaceP
Here
So i have been having to odd problem when i used my electric boost for the hot water in my own house, sometimes it would not control the temperature correctly and effectively turn into a kettle. I don't use it too often so its never been a priority. My plan was to get a new thermostat tomorrow so I will check the size tonight. I found it was a 7 inch stat that had been installed, and thought it seemed a bit short. When I checked the depth of the housing I found it should be 11 inches. I think this is most likely cause of my problem, which could have resulted in severe burns the way it is currently set up.
This is something I would never have thought to check over in an inspection but now i am thinking i will look out for. Has anyone else seen this? I am wondering how common a problem this is.
The stat shouldn't be tight to the bottom of the stat pocket so it should be less than 11 inches.
If it's a horizontal element fitted in the side of the tank then it should normally be an 11" element with a 7" stat.
As mentioned above any new stat should incorporate a safety cutout device.
Reply to Water heater thermostat in the UK Electrical Forum area at ElectriciansForums.net
Thanks mate, not something I have a lot of experience in. But that makes perfect sense
There is no reason for an item of fixed equipment to be on its own dedicated circuit just because it is fixed equipment. There may be other...
loz2754
L
