water heating thermostat | on ElectriciansForums
Discuss water heating thermostat in the Talk Electrician area at ElectriciansForums.net
i=p/u
Northern Ireland
the hot water in my house is scalding nearly boiling, i have oil heating system and imersion heater that heats the water would there be 1 thermostat for both on boiler and where abouts would this be???? if you can help
Each system should have a thermostat, sounds like something has failed, the immersion should have a thermal cutout.
well the heating hasnt been on today but immersion has..., we were changing immersion heater circuits/cables last week but didnt touch anything else. how would you test thermal cutout??? isit a simple change over????
Reply to water heating thermostat in the Talk Electrician area at ElectriciansForums.net
H
Boiler Programmer I have a wall mounted thermostat which is connected to a 26 volt supply from my Glowworm 24ci boiler. I would like to replace...
homebrewer55
H
R
Hive thermostat multizone help Can anyone help me. I have just moved house and we have a boiler with a separate hot water tank and then 2...
Rick1980
R
