T
timo
Best was to water tight some SWA glands? I've got the weather (outside) gland packs but they only seal to the aromored cable and not to the accessories. Best way to seat to IP rated box's etc in garden lights and where they will get rained on ALLOT
Also is there some better glands around than the old style yet? lol quicker methods ? Think i need more pracy on 6mm upwards :o
Cheers
first of all use CW glands. Then use an IP washer between the gland and the box. When tightening the gland on a CW, you dont leave as much of the armour out of the sheath as you do on a normal BW gland. Make sure the olive is on the right way round, or it wont tighten up properly. Also make sure the sheath of the cable, before the point where the armour is stripped, is inside the compression part of the CW gland (the rubber bit). Make sure you tighten the compression part of the gland, but dont overtighten, as the seal will fail!
When istalling the box, ensure the rubber seal on its lid sits prperly on the box, and ensure all screws are tightened equally. Most IP67 boxes have caps that sit over the screws that you use to secure the box onto the wall, but i dont trust them, we used to use industrial sealant to cover the screw so no water could enter the box. another method is to drill small drainage holes at the bottom of the box, provided there is no way water could enter from the bottom.
However in my experience (installing water features) the only way to truly give a maintenance free waterproof connection is some sort of resin joint!
PS, some rubber seals can be tightened and still seep water. You can put vaseline on the seals and it works wonders! we used to use it on the seals in pumps and valves.
John
yea lenny but price doesnt always equal Quality just like beer lol my old gaffer got a Job lot of cws they were ace n cheap Newlecs own seem to be no bad as are Electric centers
Water Tight SWA
Australia
timo,
pennywise,
