Kamkam - I am on the 3rd fan already in the quest to find a suitable one, and they are not cheap! There is no 2nd internal live, which is why the external wire was installed. Even connecting this as the 2nd live - because the lightswitch has been wired with neutral/live the wrong way around, a fan with humidistat and timer won't function because the lightswitch does not operate correctly. The 2nd electrician explained this to me, but it's not my forte so I can't relay what he told me very well I'm afraid. trust me - I have tried several upgraded fans and none worked. The latest Airflow does work - but that's on a 13amp and is incredibly noisy. I only tested it on the 13amp to check it would work, and this is the reason for the original investigation looking for an inline fuseholder. I thought that would solve all my troubles. How wrong was I!
I'll try and explain where the fan is: it's on the wall opposite the doorway into the bathroom, on the right hand side, near the corner of the room. Immediately opposite said doorway is the bath along the wall. The fan is not above the bath which is on the left side, but is about a foot further along the wall in the right corner. The taps on the bath are on the end furthest from the fan. The fan is about 2m 20cm high I would say. (am not currently at home to measure it).
The shower is immediately on the right of entering the bathroom, and is a cubicle, it's in the corner with the long side (it's on an oblong tray) along the wall opposite the fan (same as the doorway into the room).
The cable from the light switch to the fan goes above the celing. At point of renovation, a chimney breast was taken out. This left a big enough hole in the celing to get to the wiring then. This was replastered as part of the renovation. There is no access from above due to no loft, and I am unsure where the junction box up there is to just cut a small hole away. Even a small hole requires replastering though, which is not ideal when the shower is constantly in use so it wouldn't dry out. It'd need to be a sizeable hole to get up there, too...
I can't believe how much this whole thing has cost from start to miserable finish, and it sounds like I have an extremely dangerous situation.
I am in North London. Anyone able to help a totally naive 1st home owner in distress? I feel like I have learnt a very valuable but painfully expensive lesson, and need to get this sorted so it's safe, but in the least expensive way possible. The loddgers are simply to help me pay for the mortgage - I do not have a lot of disposable income as you can imagine for a 1st time homeowner in London!
