Guest viewing limit reached
Hi, I have outdoor lighting in my garden in the form of rectangular LEDs that are cabled around through the flower beds. Each light is connected to the circuit with its own wiska 3 way junction box. Unfortunately the lights have all failed and I need to replace them. So, two questions please:
1) As the cabling and boxes are already there, should it be straightforward enough to swap the lights myself?
2) any recommendations for more reliable waterproof garden lights please? They should be quite bright as they uplight into the trees above...
Thanks for your help!
Dan
Bucks
United Kingdom
waterproof outdoor garden lights
DIY Electrical Advice
Thread Tags
Tags Tags
None
DIY DAN,
