watts and VA | on ElectriciansForums
Discuss watts and VA in the Electrician Talk | All Countries area at ElectriciansForums.net
U
Unregistered
Whats The Difference Between Watts And Va.
What Does It Mean , Is Watts The Power Consumed And Va The Power Available
In a simplistic view, then yes.
If you want the more technical answer, the VA is purely a product of the Voltage produced by the supply and the current drawn from the supply.
Watts is a product of the voltage dropped accross the resistive element of the load and the current drawn from the supply.
Volts Amps Reactive (VAR) is a product of the voltage dropped accross the reactive elements of the load and the current drawn from the supply.
the difference between these values is the Power Factor (ie Watts / VA)
With a power factor of 1, with a purely resistive load (although in practice all loads have some reactive elements) then Watts would equal VA. A generator rated at 10KVa would supply 8Kw at a power factor of 0.8., and 10Kw at unity power factor
VA is quite often refered to as "apparent power", Watts are "true power" and VAR is "reactive power"
All off the top of my head, but I hope this helps!
Reply to watts and VA in the Electrician Talk | All Countries area at ElectriciansForums.net
The bank is a group of batteries connected in parallel, or series, or a combination of the two, and get charged as an entity. Assuming they are...
