Hello all,
This question has always puzzled me - hopefully you will be able to help?
I'm looking at replacing my main lounge light, as it's current light low voltage transformer has failed - so I want to replace it with a mains voltage light, to prevent any more transformer issues in the future.
I've seen the replacement light fitting I want fitted, which takes, 4 x 40 watts max, ES/E27 standard bulbs - although, for a main light, in a 5m square lounge, I'm concerned it will not be bright enough for my requirements...
... so, I though, as I can have 40w max incandescent bulbs, could I use 9W or even 12w E27 LED bulbs instead? As my understanding is that LED run a lot cooler than incandescent bulbs?
I ask, as the supplier of the light fitting, says I must stick to 6w LED (40w equivalents) and not go higher?
Any help will be greatly appreciated
Many thanks
Jamie
Many thanks
Jamie
