Weatherproof timer ans Spur Unit | on ElectriciansForums
Discuss Weatherproof timer ans Spur Unit in the UK Electrical Forum area at ElectriciansForums.net
london
Hi
Does anyone know of a weatherproof simple on/off timeswitch and Switched Spur thats available? Its going to be undercover, so not in direct contact with rain/sun etc but there will be moisture.
Welcome to the forum mate.
What is the timer switch switching? Max amps needed.
As an Amazon Associate Electricians Forums may earn a small commission from qualifying purchases.
Yeah, the only thing is it needs to be pressed whereas i just need it to be automatically switched on via the timeclock.
If you don't need to physically switch it then why can't it be mounted nearer the light? Then no need to be waterproof.
Reply to Weatherproof timer ans Spur Unit in the UK Electrical Forum area at ElectriciansForums.net
J
The rcd spur being fitted is probably because there wasn't rcd protection of that supply.
