R
Roger
Went to look at a house today ,present owner been in there for 44 years and brought from new.
All ring main sockets have green slim weeping from them ! it is down the walls on some and is on the skirting board, removed one and the old grey twin and earth lookes like the pvc is breaking down and secreting something used in the construction of it.Most of the plugs used on the sockets have green residue on the pins as well.It only appears to come from the live and neutral insulation as the earth wire looks clean.
Took the cover of the old fuse board and there is evidence of it happening in there as well.
I thought it might have been damp initially but not the case.Its that sort of copper oxidation ssen outside.
I will return and guess do a IR test on some of the circuits and this should give me a indication as to the extent of the problem.
Has anyone seen anything like this before ???
