weird one....... | on ElectriciansForums
Discuss weird one....... in the UK Electrical Forum area at ElectriciansForums.net
ExArmy
cumbria
in my drying room i have 2 batten holders with CFL's in them, and a 4" extractor fan controlled by a built in humidistat.
i went to turn the lights off as i left before and a weird thing happened, i had some keys in my hand and as i tried to turn the light switch i only got it halfway as my hands were full and i couldn't press it in all the way, the lights were flickering when the switch was at halfway, and as the lights were flickering the fan fired up!
then i tried to replicate it, everytime i hold the light switch halfaway, the lights flicker and the fan turns on.
so whats the science here? i'm thinking it wouldn't do the same if they were incandescent lamps. sometihng to do with capacitance/inductance and induced voltage??
if the fan isolator is switched off : nothing hapens as the lights are flickering
if one of the CFL bulb is removed: the fan barely moves as the lighs are flickering
if both bulbs are removed: nothing happens
I read the OP 3 times and I'm still not sure what you're explaining. Are you saying the keys in your hand are making the lights flicker or is the switch sticking in the halfway position?
Probably ex Cavalry, he's now retired to the ante room for cigars and port to discuss the finer points of defeating the fuzzy wuzzies who came at them with sharpened mango fruit.
A conversation that gets Rowley Birkin QC quite excited and very very drunk... :lol:
i went to turn the lights off as i left before and a weird thing happened, i had some keys in my hand and as i turned the light switch off and the lights flickered as the lights switch was halfway on if you know what i mean. as the lights were flickering the fan fired up!
then i tried to treplicate it, everytime i hold the light switch halfaway, the lights flicker and the fan turns on.
When you hold the light switch half way and the lights flicker, this introduces high frequency electrical noise on to the connected lighting circuit wires.
This electrical noise is then picked up by the energised fan control electronics, and makes the fan to trigger falsely.
no i just had my hands full and couldn't press the switch fully so it only went halfway and then the lights started flickering as the current arced accross the switch contacts.
Ahh, it was the keys thing that confused me. Switches are meant to be snap action, even if held in the middle they should either be fully closed or fully open. I know it doesn't answer your question but if it arcs when operated slowly I'd replace it.
My house is a drying room, socks and ids clothes on every radiator, typical British summer.
I hope you beat Jeeves daily to keep him in check? Is your house maid a ripe young filly?
Reply to weird one....... in the UK Electrical Forum area at ElectriciansForums.net
Neutral and live
Switch by the door, pendant holder and a 100W bulb, some will remember, others weren't born yet when it went out of fashion, but this was the...
