Darkwood
Went to solve an issue on a lathe which is just part of my daily routine but while their i was ask to look at an issue in the calibration room.
Scenario:-
Ring main has numerous measuring and balancing equipment plugged in - all small power item.
Computer stack that is linked to dual monitors and then data linked to a high resolution camera inspection microscope... within this microscope is a ring of led lights around the camera lens so far nothing out of the ordinary well! until while the led and camera are on and the computer software is relating the picture from the camera... all works fine until one other item of equipment is switch on in the lab 'a small magnifying glass with a circular florescent lamp' the minute the lamp is switch on the led's and camera on the microscope switch off and the computer gives a warning tone the same as when a USB is unplugged.
This is not coincidence!.. I repeated the scenario a few times and the computer program requires rebooting to gets things back to normal.
The are 5m apart on same ring main.
The flourescent lamp is small prob 18w ish but switch start.
Using a filter on the sockets does not rectify the issue.
My conclusion is RF signal interference matching the switching commands on an exposed PCB board at the camera/led position that is housed in a clear plastic cover...
Im going to return with a PCB starter for the magnifying lamp and going to glue a RF shield to the plastic cover housing the PCB control card for the camera and LED lights...
Im on top of it as most will know I don't often get stumped but just an interesting fault and wandered if anyone else had had similar freaky issues.
Note ring main test out fully and no issues with plugs etc...all common tests and observations were done and satisfactory.
Scenario:-
