Hi, I'm having a strange problem with a reverse light bulb. I replaced the bulb with a new one as it didn't light up but it still didn't work. I've tested the bulb and it works (tried several new ones as well). I've tested the socket with a meter and get 11.8v. To rule out potential bad connection I've put 2 wires directly into the correct pins on the connector and tried the bulb- still nothing.
If I monitor the voltage, it stays at 11.8v until the bulb is in the circuit and then it drops to 0v. Then I remove the bulb and it goes back up to 11.8v.
Any ideas what may be going on?
Thanks in advance!
Thanks in advance!
