Discuss well suction negative pressure plumbing advice in the Plumbers Forums area at ElectriciansForums.net
well suction negative pressure My pump is lifting water about 20 to 25 ft through 1-1/4" pipe at about 800' above sea level. Can anyone calculate the negative pressure at the pump for me? I'm just not that bright. I've recently installed a check valve near the pump and am having some issues with the system sucking air in and losing prime. Just curious to know what numbers I'm up against.
