went to fit immersun & found this installed 2 years previous by solar installer | on ElectriciansForums
Discuss went to fit immersun & found this installed 2 years previous by solar installer in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
marc8
Essex
Says it all seen about 8 like this so far.
[ElectriciansForums.net] went to fit immersun & found this installed 2 years previous by solar installer[ElectriciansForums.net] went to fit immersun & found this installed 2 years previous by solar installer
It's astonishing how frequently people make that mistake. I honestly cannot understand why people struggle so much with such a simple concept.
not impressed especially as it was a m8 & to cap it all (first job) MCS inspection on same day for the fella, but at least the paperwork was all good if you know what I mean
Would you be able to get a copy of the MCS certificate, and a signed statement from the customer that this system was inspected and approved by an assessor?
I'd like to take this to the MCS steering group as evidence of how poor some of the assessors are / how lax the enforcement is when it comes to the actual technical side of the installation as opposed to the paperwork.
I will be in Chelmsford over next few days if I get time I will pop in & see the owner, I am sure he will dig it out & can compare the dates for you, sure he will
it was this guys first job
yeah I'm not intending to make any trouble for the installer if it was the first job and being assessed, it's the assessor who's responsible for signing this off and allowing this installer to become MCS certified, and potentially end up installing further systems in the same way.
Reply to went to fit immersun & found this installed 2 years previous by solar installer in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
I would expect it to be virtually impossible to complete the project safely. how would you fix the panels to a roof that you can’t disturb? when...
You need to pass the job on to someone who is competent and up to speed with solar installs and regulations .
