Wessex led floodlight | on ElectriciansForums
Discuss Wessex led floodlight in the UK Electrical Forum area at ElectriciansForums.net
gazdkw82
leicester
Anyone used any of the wessex led flood lights from toolstation? Iv just installed a 30w with pir.
After install and testing, turned it on and it's very dim with a few leds on the board not lighting at all.
Anyone seen this?
  • [ElectriciansForums.net] Wessex led floodlight
assuming it is installed correctly, it is a faulty unit.
send it back
a 30w led floodlight is not something you are comfortable staring at for more than a second.
I think it was a Wessex I installed a little while back with no problem. I've had issues with the older style LAP ones not lasting that long - in fact found one full of water a while back which really shouldn't be possible since they come pre connected with a flex....
I think all the ones at the budget end are much of a muchness... At least it's fairly easy to swap at Toolstation or Screwfix.
Slightly off-topic here, but LED...
I bought this:
https://www.screwfix.com/p/erbauer-...VDu3tCh1fxARAEAQYASABEgLdQfD_BwE&gclsrc=aw.ds
a couple of days ago, and it is amazing (so far) for the price.
Excellent portable light source, and even runs at 1/4 power while charging.
Yep - have one of those myself and works very nicely for CU changes. The chippy I work with has one and calls it his Ebola light....
Amused by the fact that they call it Wireless though - hitting those search terms...
I've got one too. Got a unilite work light that was much more expensive and I have to say the erbauer is better in every way battery life if far longer
Interesting.
It was reviews mentioning battery life that put me off rechargeable erbauer lights. Unilite receive high praise from youtubers, but good to read real life experiences.
Reply to Wessex led floodlight in the UK Electrical Forum area at ElectriciansForums.net
Thanks davesparks. Looking at the diagram on the driver that's what I interpreted too, but I heard somewhere that the DALI system doesn't like...
I tested the supply with my AVO, I also confirmed the PIR has the same supply coming out. Readings are 247 Volts on both. This was tested between...
