daruvalla
I've recently had a 3.6 Kw system commissioned involving a 7 panel 230W string on a west facing roof and an adjacent 9 panel string with the same panel type on a south facing roof.
The system has been installed with a Deihl 3800s inverter and the two strings have been connected from what I understand together in series before going into a single input on the inverter (single MPPT).
The system seems to be generating power (about 1-2 Kw per day at this time of year) but I am concerned that the efficiency of the system is reduced due to way the two unbalanced strings are joined into one (ie. the west facing 7 panel string compromising the output of the south facing 9 panel string when there are different levels of light on each orientation earlier in the day and vice versa later in the day).
I was under the impression that joining two unbalanced strings into a single MPPT input is not good practice and inefficient?
I haven't tackled the issue with my installer yet as I wanted to keep an eye on the output for a while and get more information before I do so. Am I right in assuming that this system should have been installed with an inverter with 2 seperate MPPTs for maximum efficiency, or failing this 2 seperate smaller inverters?
