Western Power | on ElectriciansForums
Discuss Western Power in the Australia area at ElectriciansForums.net
South Wales
One of our white goods engineers called me out to a job the other day because he noticed a high ELI on the socket circuit his machine was being installed on. Anyway he asked me to check it out so the first thing i did when i got to the property was to do a Ze. When i got there on the TN-C-S system the Ze was 10.14 ohms. I proceeded to call out Western Power to check this out and I waited in for him to see his verdict. He confirmed that it was indeed a TN-C-S system as sometimes as you know people try to create their own PME :D. He said it was reading fine to him so he stripped out the tails at the cut out and reconnected and tested again. He got a Ze of 0.78 ohms now and said there ya go all it was was a loose connection. But when i questioned him as to why he seems to think a Ze of 0.78 ohms on a PME system was he said oh its fine we allow up to 0.8. I told him that i think he is getting confused with TN-s gbut he confirmed to me that they definitely allow up to 0.8 ohms on a PME.
All i did was to fill in a minor works form for the circuit i tested with all the test results etc and note down the job reference that western power gave me when i called them out in the notes.
Is what I have done ok? Now I know that I am right in saying the results were wrong byut what can I do when they wont change a thing because they insist that it is correct?
think you should of stuck to yer guns m8 and asked to speak to the engineer above him.
finished a job a month ago a rewire and the Ze was 0.50 ohms on a TNCS system , made the call and lads were round in a couple of hours ,turned out to be a faulty transformer.
after the fix the Ze was down to 0.20 ohms happy days.
Reply to Western Power in the Australia area at ElectriciansForums.net
Ok so just done a quick test on mine. Megger mft on high gives 0.30 Robin 4120dl on 20ohm hives 0.22 Robin 4120 on 200ohm gives 0.28 Bearing in...
The challenge that you have with this is that you've no confirmed start point. Because you have a lack of an EICR you don't actually know what...
