Borrowed my neighbours Titan wet and dry vac with a Bosch hand sander. The sander plugs directly into the wet and dry vac by way of a 3 pin plug. when you press the trigger on the sander the vac sucks the dust away (attached with hose to sander)
I noticed I got a few shocks from the sander whilst using it.
I thought I'd try doing a Zs from the outlet point directly on the wet and dry vac but all that did was pulse the vac on and off a few times and then came back as 26ohms.
I ran out of time but I plan to investigate further.
What tests would you recommend? IRT? Earth Continuity?
