what about tv, satelite , phone wiring? | on ElectriciansForums
Discuss what about tv, satelite , phone wiring? in the FreeSat, Sky, VirginMedia Forum area at ElectriciansForums.net
H
hcpunk
hi i want to find out how 2 wired up (all in one house , one family) a 5 or 6 phone points , and a 5 0r 6 tv or sat points (i'm not sure what " do with tv/sat , what the best way ? please help
By no means a telecoms engineer but I'm pretty sure you can only have max #3 phones on one circuit. (REN ?) Now with cordless that shouldn't be a problem. For splitting your TV Sat get a TV Sat Splitter?Amplifier. You should be able to get a duplex outlet that carries 2 signals on 1 cable
He's right - depending on line voltage can be as low as one phone and one answerphone. If you def need that many phone outlets you will need a REN Amplifier, and wire them in parallel, terminals 2 and 5 in a standard phone outlet..
You can use a REN booster to get a REN of 11 BT Extension Booster
I did use quite a few of these some years ago but the market has changed a lot and phone systems are alot cheaper than they were
Reply to what about tv, satelite , phone wiring? in the FreeSat, Sky, VirginMedia Forum area at ElectriciansForums.net
All you can do is try it and hope it works out. Shouldn’t be a hazardous condition. Good luck
This thread can now be closed, as I seem to also have space in the box for the first switch. Revised diagram below. Thanks folks.
