What am I looking at? Steel CPC? | on ElectriciansForums
Discuss What am I looking at? Steel CPC? in the UK Electrical Forum area at ElectriciansForums.net
JamesL1892
Birmingham
Hi all,
This is found behind a single socket, house probably wired 1970.
Can you tell me about the steel wire earth?
Why does this differ to the copper cpc throughout the house?
[ElectriciansForums.net] What am I looking at? Steel CPC?
Sorry? Not following. Please explain. Thanks
He means the live conductors are also twisted, braided tinned copper…. It’s not just the cpc.
They tend to break under the terminal screws if disturbed… just cut off up to the broken bit a strip a little more insulation…. Carefully
The insulation will feel a lot tougher than modern PVC
Early 1970's wiring as previously mentioned could be aluminium if you scratch the cable surface with a knife or a file if it is tinned copper the copper will be exposed if you don't see copper then it is aluminium which given it's age will by now be quite brittle, if mixed with copper in the same connection there is also the possibility of galvanic corrosion
Just a point. Some of the comments I make are, as in the case above, intended to make the questioners/learners think for themselves, without giving them a full explanation.
Most people can probably think for themselves, with a bit of cajoling, perhaps.;)
Reply to What am I looking at? Steel CPC? in the UK Electrical Forum area at ElectriciansForums.net
I do not think so, rather someone has seen that this cable is cheaper than what was ordered and thought to save some money. Yes Steel Tape needs...
It's the same with any system, if you put poo in, you get poo out!
In my opinion replacing the consumer unit and waiting to see which RCBO trips is not a good fault finding technique. If the lighting circuit...
davesparks
"A catalogue of errors" would be the appropriate phrase here and I agree with Avo and James that HSE need to be involved rather than this forum...
CONCLUSION (Couldn't see how to edit title) It was not belting it down with rain today, so lifted the manhole cover. The pump is about 2 metres...
5K
