F
FB.
I already have 3.75kWp.
As some of you will know, for a few months I've been pondering additional solar PV by adding another 2.5-6kWp, and how it could be done, or even IF it could be done.
So the following is a map of my local area, with the nearby PV arrays marked with yellow circles; there are about ten others within a mile, with a smaller number of other arrays in adjacent estates off the edges of the map.
Most of the arrays look to be around the 2-3kWp size. I am fortunate in having a peculiarly large roof with no obstructions - hence a larger array than most nearby - including the larger houses.
The entire estate was built around 1987-1992, my house being one of the later ones to be completed (about 1991?), with single-phase supply to my house, 63Amp on the CU, if that makes a difference on the likely ability of the local grid to support PV.
So.....what do you think are the chances of the DNO (UK Power Networks) agreeing to me adding another array?
No chance?
Good chance?
Thanks,
F
No chance?
Good chance?
Thanks,
F
![00000000000000solarroofviewlocalinstallations2nsm.jpg](/proxy.php?image=http%3A%2F%2Fi459.photobucket.com%2Falbums%2Fqq315%2Ffluffybuck%2F00000000000000solarroofviewlocalinstallations2nsm.jpg&hash=bc7c8f3b834e2c9753301167e4935796)
