T
TPES
If your Extending or altering a circuit that is on a Rewireable fuse but you need to comply to 17th regulations, Meaning the need for RCD protection, What options do you have getting this to comply??
Discuss What are my options for Rewireable circuits without Changing CU in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Sockets are an exception because you use portable equipment in them then a rcd is always needed now, although in certain situations you can get round this i doubt these exceptions will ever apply to you.So if you run a circuit in trunking YT2 being for socket outlets or lighting circuit then your covered and dont need an RCD?
i asked a similar thing a while ago that said if you add to a circuit you have to make sure the whole circuit complys
i
Not quite the guidance given by the Electrical safety council
Here is a link to the relevant page It will advies on a number of solutions
Look at eda 1
Alterations and Additions in Domestic and Similar Premises
Reply to What are my options for Rewireable circuits without Changing CU in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
