What Are Your Solar Pv's Generating? | on ElectriciansForums
Discuss What Are Your Solar Pv's Generating? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
Dan
Staff member
Admin
Mod
Solutions
Staffordshire
What are your solar PV's generating?
I have two 4KW systems averagely producing 3200KWH each a year. Both are at the highest rate and index linked for 25 year. I haven't looked at the figures in a while but I think I'm getting around 45pence per KWH produced and 3pence for export based on 50% of what's produced. so just shy of 3K a year...Over 25 years that's ÂŁ75K (likely to be more due to being index linked). The money goes straight in to an ISA (pension). Cost me about ÂŁ10K to install both systems. Roughly 30% gross yield which is a lot better than any ISA had I left to 10K in the bank.
Go here and you can get all sorts of data, better still hook your own up to it as well :)
http://pvoutput.org/
The guy who's the highest Brit on the scoreboard (21st place) needs help get his solar health up, for some reason.
Maybe we can help him?
[ElectriciansForums.net] What Are Your Solar Pv's Generating?
Reply to What Are Your Solar Pv's Generating? in the Solar PV Forum | Solar Panels Forum area at ElectriciansForums.net
If the batteries are charged and the house is taking little then the full production of the panels will be dumped into the grid. As you have set...
You need to pass the job on to someone who is competent and up to speed with solar installs and regulations .
