What cable type is this? SWA? | on ElectriciansForums
Discuss What cable type is this? SWA? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
jon557
Portsmouth
Hi folks,
My building has a lighting circuit for the car parking area, the outside cabling is primarily a thin ridged (what looks like 1.5mm core) white cable. It basically looks like a form of shielded cable but not braided, it looks like a solid metal tube. Does anyone recognise it? if I eventually upgrade the fuse board to a modern consumer unit does it all need ripping out?
Thanks!
[ElectriciansForums.net] What cable type is this? SWA?
Hi folks,
Thanks!
MICC, Pyro Proper cable used to be installed by Proper Electricians, that install is a right mess, whoever did it want's to be pilloried, a disgusting example of today' s I#ll say tradesmen with my fingers crossed, and as for not knowing what it is, well.
Further on from this cable an extension says the brand "Pyrotenax", it's orange. I don't like the termination and really don't like the white flex that then goes into the fuse board, currently noting all the improvements needed. This building was put up in 1985 so I am guessing this connection is about that old.
You seem to be not impressed that I didn't know what it was, well I have only just done my domestic installers course a few months back and I have yet to see all the variants of cable throughout time - I'll get there, everyone has to learn. I have a degree in electronics but practical domestic installations I am still picking up.
Cheers.
No one was criticising you but to gland that cable correctly the existing pot, the barrel bit will need removing to fit the gland then a new pot fitted and the time clock shifting down a bit. The other cable can be glanded correctly to tidy it up.
Reply to What cable type is this? SWA? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
All the lamp post cutouts I've ever seen have a twin swa gland plate built in to the base.
loz2754
L
Yes the first bit is just standard wiring, TNS lead cable into cut-out, cut-out to meter, meter to DP isolator, top of isolator is sealed as per...
