what cert to use | on ElectriciansForums
Discuss what cert to use in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
davetherave1979
Hi every one installed a fan in a bathroom and installed bonding gas water can we get away with using a minour works or will it have to be a eic thanks
As above, if you've connected to an existing lighting circuit for the fan an MEIWC detailing what you have carried out. Jobs a good un.
thanks ever one part p has been done also got a day in wrighting up loads of certs
there was no cpc in the lighting circuit but there is a separet cpc running around in the loft to the lights so they were protected what should i wright in the departures box
all rcd protected earth goes to all the switches that was newer cable with cpc in all test out ok just not sure what to put in the box on cert the board is new split load mcb 17th board fitted by a nouther sparks but no cert for it just lighting circuit
Reply to what cert to use in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Thank you all, yes I didn’t think they do and I have done minor works but the helpline was not very helpful. Got my yearly assessment soon so I...
I always used to use the free forms I found on-line, they were a little bit out of date but still held all the relevant information and were good...
