What Certificate | on ElectriciansForums
Discuss What Certificate in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
EddieB
Morning Boys
The Meter is being relocated in a dwelling so I'm installing a sub main to the Consumer unit from the new meter location, UK Power have asked for a certificate relating to the existing system, what certificate would this be, can you assist?
Reply to What Certificate in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
As the cable itself has had the cpc cut off at both ends I would enter a C3 as it doesn't offer any protection within the cable if accidentally...
Do a minor works for connecting the new gas boiler and add some notes regarding the addition of the bonding.
