What code for this EICR if any | on ElectriciansForums
Discuss What code for this EICR if any in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
London
Hi I am carrying out an EICR. I have a garage mini sub DB supplied via 2 x 2.5mm T&E equivalent 5.0mm protected at main DB by a 32A mcb.
I know this is bad practice to install unless using bigger SWA to achieve required csa's in awkward spaces to terminiate.
My question is what code is this? Im going with C3 with recommendation to rectify, but there is an inadvertent danger if 1 leg had a loose termination or worse was removed causing remaining leg to bear the load while being protected by an over rated mcb.
Any help greatly appreciated.
Smarky
Smarky
Smarky
Smarky
Are both runs exactly the same length and routing?
No worries. I was going to type something more in depth but I decided to sit in the garden with a beer. I've coded that C3, because two beers will be an improvement.
Im about to do exactly the same and open a couple myself, Its nice and sunny where I am, enjoy!!!!!
Reply to What code for this EICR if any in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Recommended Sponsor News
thanks for the clarification. ( also thanks to Dan. ).
More info on link below http://sbsc.uk.net/
9K
Happy Friday Everyone! Subscribe for more jokes direct to your mailbox or send us your own jokes to be in with a chance of featuring, by clicking...
6K
