What code? Shower switch in zone 2 | on ElectriciansForums
Discuss What code? Shower switch in zone 2 in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Pretty Mouth
Warwickshire
A pull-cord shower switch is located in Zone 2 of a bathroom, including the ceiling base containing the electrical connections. With a little effort it may be possible to get spray from the shower onto the base.
I assume this is a C2, but wondered if anyone here might give it a C3, based on it being a pull switch so no direct handling?
There will be millions of light switch pull cords in small bathrooms exactly the same.
How high is the ceiling? There’s a vertical limit to zone 2 if I recall
Reply to What code? Shower switch in zone 2 in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Being pedantic, the Crabtree 50A cooker switch is a 4500/1, which has 'cooker' printed on it. For a shower, you require the 4500, which is the...
There is no homework, and I'll never see these photo again.
