what code? | on ElectriciansForums
Discuss what code? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
J
jimes
2 ring mains split over 2 breakers? guess they got mixed during a board change and not picked up, obviously not tested properly. what code would you give this?
I would say 1 as it could be very dangerous for isolation purposes.
But then agan if I discovered it during a PIR I would just carry out the remedial straight away for how long it would take, unless of course it was in 2 different DBs.
Reply to what code? in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Absence of correct labelling is a C3, reversed polarity is a C1 (BPG-4). You choose.
True. Although I'd hazard a guess that things like woodworm treatment are probably chemically quite similar? Don't know.
