can anyone help with the connection for the switched live from the bathroom fan in this fuse box. it is the unconnected yellow wire with a red sleeve and i assume it goes into the top right OUT connection with the single red wire. Thanks in advance
Discuss what connection to make for the fan switched live wire in a fcu in the UK Electrical Forum area at ElectriciansForums.net
That is one of those "Where to start" without being overly negative pictures.no way of teling over internet. needs site visit with test gear to determine which conductor does what. it looks a mess and will probably need some reconfigurations, maybe a 3 pole isolator, and critically circuit needs to be RCD protected, and fan manufacturer's instructions followed, e.g. 3A fusing.
thanks for the information. it has a 3a fuse in the box and it is protected at the box in the garage. i think the electrician who wired it in 20 years ago fed the switched live into the fuse box and just cut it off instead of connecting it. think i'll have to get an electrician around.no way of teling over internet. needs site visit with test gear to determine which conductor does what. it looks a mess and will probably need some reconfigurations, maybe a 3 pole isolator, and critically circuit needs to be RCD protected, and fan manufacturer's instructions followed, e.g. 3A fusing.
That is definitely the best option. Let us know the outcome would be good to know.thanks for the information. it has a 3a fuse in the box and it is protected at the box in the garage. i think the electrician who wired it in 20 years ago fed the switched live into the fuse box and just cut it off instead of connecting it. think i'll have to get an electrician around.
maybe if you posted your location, one of us maybe close. a forum discount on the cost might be applied.thanks for the information. it has a 3a fuse in the box and it is protected at the box in the garage. i think the electrician who wired it in 20 years ago fed the switched live into the fuse box and just cut it off instead of connecting it. think i'll have to get an electrician around.
it would be nice to help out a fellow member at a rate slightly below normal.@telectrix WHAT since when being on here do I have to give discount?! I missed that memo
Reply to what connection to make for the fan switched live wire in a fcu in the UK Electrical Forum area at ElectriciansForums.net
