What CSA would you say? | on ElectriciansForums
Discuss What CSA would you say? in the Australia area at ElectriciansForums.net
Amp David
Mentor
Glossop
Looking at this picture, what size CSA would you the black bit of cable is?
For reference working fronm left to right we have
2.5mm, 4.0mm, ?mm, 6mm
[ElectriciansForums.net] What CSA would you say?
I've been told by the old boys that it is possible to order any size, any colour, any core you want from a manufacturer. Why they would go for this in-between size is any ones guess. I think it may have been a bad batch of what should be 6mm, sold cheap and still used. How many strands does it have? (how much can we debate this 2 inch of cable?)
Its made up of seven strands.
Because they're yanks mate, they only have inches
Yeah, I know that. What I was meaning is why is it being used here in the UK, would of thought that in 1989 it would of been metric.
Can't see it being an odd off cut either, as there are 11 houses with the same install into the garage, all with a run of 12 meters.
try measuring the resistance. and swg is english, it's them damn meters that are foreign. meters are for putting shillings in to make the lights work
standard wire gauge. as on 7/029, now replaced by 2.5mm. the 7/029 was far superior. just done a CU change where most was 7/029 for ring finals. 3/029 for lighting. all readings well perfect and it's 40 years old.st on case you don't know already. the 029 is the swg of each strand, and the 3 and 7 are the no. of strands.
Reply to What CSA would you say? in the Australia area at ElectriciansForums.net
L
Trying to source an obscure size octagonal tile I hope you can help we are trying to source (for a match) some 300mm by 300mm matte white taco...
Lisa Rogers
L
