What CU | on ElectriciansForums
Discuss What CU in the Australia area at ElectriciansForums.net
A
ajelec10
Whats your thoughts on consumer unit set ups we only use straight boards with indivudal RCBO protection, this is the most expensive way but surley the best?? also you dont need to alter any thing if you come accross a TT installation.
AJ
Reply to What CU in the Australia area at ElectriciansForums.net
If two tariffs are sufficient, and you don't need too many ways, you can easily add an SPD kit to the Fusebox F2014DT dual tariff board. The only...
Sounds more positive.
