Question for trainees only. No qualified sparks to post answers. .
OK. so some time ago, I picked up a Sangamo Analogue Ammeter A.C/D.C. (manufactured 1963) from a car boot for ÂŁ2. Been lying around for a bit. Thought I's see how it performed.
So.. 12V PSU +ve to 1 end if a 1.2 ohm 1/2 watt resistor. other end of resistor into teminal on the ammeter othe ammeter terminal connected back to -ve of the PSU. Switched on PSU, the ammeter needle kicked up to 1.5A then back to Zero. what should it have read and why did it do what i described?
So lads/lasses, if any, why do I need to go back to school?
@ Lister. give the younger ones a chance first as i think you'll know the answer.
