What do we need RCDs fit anyway... | on ElectriciansForums
Discuss What do we need RCDs fit anyway... in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Cheshunt
Not sure if there is a specific group for posting things like this?
When your RCD stops working this is a much cheaper remedy to the problem..
This issue was quickly rectified for the customer (correctly)
[ElectriciansForums.net] What do we need RCDs fit anyway...
Right old cock up is that.
Shorting out the RCD for continued operation is something I wouldn't have considered as a method of providing a safe electrical environment for the clients...
Do you know why it might be dangerous? DO you drive a vehicle with wheels or legs?
With a very large CSA cable at that!
Is this bypassing the RCD, or just getting a live to the MCB because the bus bar is too short?
What is that cable covered in black tape in the RCD Neutral?
Just to clarify. This is how I found the board, not sure if my sarcasm came over correctly in my post. I hope no one thinks I was suggesting this was actually my remedy.
I have put a new RCD in. It is a temp fix as it is not a Volex RCD as I’m struggling to find a source for a Volex brand? Can anyone suggest a compatible brand or should this be a complete board change if Volex no longer exist (surely not tho?)
The RCD has been bypassed because it wasn’t working so non of the socket circuits were protected.
I found it by chance because I was there to do an unrelated job
Reply to What do we need RCDs fit anyway... in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Thanks for the reply littlespark. Yes the works have been carried out. Surely it is fraudulent because basically the document is Not...
I usually put something like this To assess compliance with BS7671 for continued safe operation (5 year periodical inspection)
