What equation can be used here to find the value of the capacitor? | on ElectriciansForums
Discuss What equation can be used here to find the value of the capacitor? in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
England
Hi all,
I'm struggling with these questions for this circuit as the equations I have in order to work out impedance etc all seem to need the value of the capacitor so I'm at a loss now and was wondering if there was a way to work out the capacitor value or if there was another equation I could use in order to not need it?
Thanks in advance
  • [ElectriciansForums.net] What equation can be used here to find the value of the capacitor?
How about with the values given, you work out the voltage across the resistor, and hence deduce the voltage across the capacitor.
Then you can use a formula to calculate the capacitor value from the voltage across it, the current through it, the frequency etc etc.
Not that I've done any of this for the last 55 years so Could be wrong🤪
Upvote 0
Thank you, I'll give it a try 😊
Upvote 0
Reply to What equation can be used here to find the value of the capacitor? in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
Great, then I am a bit bemused why you posted your original question. You need to stop doing any work that you cannot properly test, safety is...
Hi I'm again struggling with a long overdue 2396 project but, as before, am at a standstill when it comes to the lighting design. Please could...
Electrical Courses
