Discuss What happen to laptop if run in AC current instead of DC and what are the effects in the UK Electrical Forum area at ElectriciansForums.net
Im just asking for curiosity,what happen if plug 240VAC directly to laptop charger port without DC adapter. What are the effect for laptop if plug in 240VAC into laptop???
Cpt Mainiwaring says !Stupid Boy no offence meantHi - I’m sure someone will reply with experience . My best effort was I plugged in a 48V DC adapter to that 12V port and I destroyed the laptop. No fires or anything but it never worked again.
Deswin if you put 240vac on a lap top you will fry it. When you plug it in it has a DC power supply built in the plugIm just asking for curiosity,what happen if plug 240VAC directly to laptop charger port without DC adapter. What are the effect for laptop if plug in 240VAC into laptop???
If you do happen to try it then make sure you capture it on video!
Reply to What happen to laptop if run in AC current instead of DC and what are the effects in the UK Electrical Forum area at ElectriciansForums.net
