What is it on this fault | on ElectriciansForums
Discuss What is it on this fault in the UK Electrical Forum area at ElectriciansForums.net
buzzlightyear
Nearly Esteemed
star command
This for an apprentice
32 amp mcb /63amp RCD
1) no power to the sockets
2) installation resistance all good.
3) contunuty good.
4) no loses conections.
5) mcb not tripped
6)rcd not tripped.
7) all mains on.
What is it.
Some MCCB's can catch out the unwary when they do that whole thing where the outside lever only moves a fraction and then you have to manually fully open and reclose.
More than once I've had customers ring to say the RCD lever is 'floppy' and won't latch on - always an MK one where you have to push the lever down first then up and they don't get it. :)
He's back again. Must be a leap year.
Reply to What is it on this fault in the UK Electrical Forum area at ElectriciansForums.net
A kettle boiling fish - thats your fault right there... or is it a red herring? :)
I would add though that a typical good TT rod of 100 ohms only needs 3V to have 30mA flowing and so trip an RCD, you might find that sort of N-E...
