What is required for Uk registration. | on ElectriciansForums
Discuss What is required for Uk registration. in the Business Related area at ElectriciansForums.net
stivernz
I also need to find out what the minimum requirements are for working as an electrician in the Uk. I have been fully qualified/registered in New Zealand for the past 20 years and want to find out if I can work under that registration or do I need to do a course for the local regulations. Anyone who has gone through the process I would really like to hear from you. Thanks Brent.
HI BRent best thing to do is contact the NICEIC the main UK professional body they should be able to tell you if your current quals etc are comparable and what else you may need. Ther eisn't one route to being a qualified electrician in the UK but several depending on what yoru working on (domestic, commercial, industrial, mix of all etc)
Reply to What is required for Uk registration. in the Business Related area at ElectriciansForums.net
I needed two all that time ago one was a colleague the other an old college tutor I had kept in contact with.
Persons who are not registered with a self-certification scheme - including DIYers - will need to notify or submit plans to a Building Control...
