what is the best way to fix a light on thin metal cladding? | on ElectriciansForums
Discuss what is the best way to fix a light on thin metal cladding? in the Australia area at ElectriciansForums.net
this is a lighting commercial warehouse, the owner wants to have a external pir light, the problem is i can only fix it on a thin metal cladding, what is the best way to fix the light? i dont think i just use a metal screw, i can not use a nut at the other side to hold it because there is a 200mm cavity, bit a headache,
cheers for any advice
Maybe pop rivet a plate about 2mm thick & 50mm longer x 50mm wider than the mounting plate of the light. Use 4 pop rivets - 1 @ each corner, then pop rivet the light's mouting bracket through both the plate & cladding?
That said, if you can't use pop rivets, maybe some decent self-tappers would do.
The main thing I think is to get the plate of sufficient dimensions in order to stiffen the thin cladding.
Mark your bracket fixing holes, use 10mm drill bit to drill straight through. Go inside, cut a length of unistrust, 2 10mm zebz, 2 lengths of 10mm threaded rod through to the outside and whala! bolt on your light.
Edit: Use 6mm if it tickles your fancy :)
usually the cladding is corrugated and there is no access behind the outer skin. a metal plate, self tappers or rivets on to adjacent proud sections of the cladding, then nuts and bolts for the fitting.
I always use pop-rivets on commercial and industrial work in this situation, but prefer to use Rawlplug expanding plate plugs for domestic work because customers have a habit of changing their minds.
Reply to what is the best way to fix a light on thin metal cladding? in the Australia area at ElectriciansForums.net
Recommended Sponsor News
Hi everyone,
