What is the equivalent resistance of this network | on ElectriciansForums
Discuss What is the equivalent resistance of this network in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
T
turbomen
Two resistors, R1 and R2 are connected in parallel. R1 is 2kW, R2 is 4kW. What is the equivalent resistance of this network (answer rounded to nearest whole Ohm):
Could you tell me how can you get the answer?
Can I do in this way:-
1/r = 1/2k+1/4k
1/r = 2/4k+1/4k
1/r= 3/4k
r=1333
But could you mind tell me about the formula? Because I do not learn the formula in before.
Cheers,
Upvote 0
You put the decimal point in the wrong place, the answer is 1.33 but you got it.
The formula is the method for calculating resistance in parallel, I don't know what else to say.
Upvote 0
Reply to What is the equivalent resistance of this network in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
Electrical Courses
