what is the error code for this one? | on ElectriciansForums
Discuss what is the error code for this one? in the Electrical Tools and Products area at ElectriciansForums.net
in the lounge there is one socket apparently installed recently which is one radial, it shares a B32 circuit breaker with a ring circuit, i thinking to make it code1 because B32 is wrong for a radial, but it looks not dangerous because the only one socket is only for a hoover sometimes, what do you guys think?
cheers
class it as an unfused spur. one socket outlet allowed. no code. but note it as a spur in comments. if you want to be picky, fit a FCU at the source of the spur.
cheers
Are you saying there are 3 x 2.5mm cables at the CU into one breaker/fuse?
If so I'd go for a "2"
if its only ONE socket outlet on the radial treat it as a Spur as this is allowed. If there are multiple socket outlets then this is wrong however as someone has already said I would personally fit a FCU for peace of mind
yes. it's perfectly OK. not the way i'd have done perhaps, but it complies to brb as yellowvanman said, so no problem. is there a spare way in the CU to fit a 16A MCB? this would satisfy God himself.
Reply to what is the error code for this one? in the Electrical Tools and Products area at ElectriciansForums.net
I have to agree with Baldelectrician on almost everything he says except one ! I wouldn’t be walking away I’d be running lol. Definitely if your...
In the 80's I was taught that with PME earthing arrangements we used 16mm for the main earthing conductor, some went a bit crazy and were bonding...
