what is the law on testing | on ElectriciansForums
Discuss what is the law on testing in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
K
krishcanag
Hi
I was interested to find out the law on testing an installation done by another installer.
Now I know no one in the right mind would approve an install if its totally not visable (cliped to wall) which will never be the case. But there are companies that have approval from councils to go in and test either DIY or unregistered installers without full details of the install and no doubt will put in limitations to cover themselves, so could a qualified sparky actually go test and approve if he thinks its good and put in limitations?
Is there a demand by councils requesting such checks or is it more or less the odd case?
KC
I wouldnt test someone elses install and put my name to it as if I had installed it, however, I would be prepared to do a full PIR on it.
If you inspect and test a new installation and complete an electrical installation certificate for that installation, you are now committing yourself to responsibility for any defects, faults or subsequent problems that occur.
You would be liable with no recourse to anyone else for any legal action that followed.
If there is a new installation that needs checking then an EICR can be done on that installation; this would have defined extent and limitations on the form and thereby exempt you from liability for anything that you could not check. It would also not have your signature as responsible for the design, construction, inspection and testing.
Why would you want to test and certify somebody else's work?
Even if you checked for cable routes with a detector to confirm they are in safe zones there is nothing to say that the cable csa is the same throughout.
The longer people certify other peoples work, the longer they will continue to do the work themselves. If they don't want to pay a spark then that's fine, they have the option of using the Local Authority Building Control for a smallish fee. IF THEY DO NOT WANT TO DO THIS THEN IT MAKES YOU WONDER WHY??? WHAT ARE THEY HIDING???
:thumbsup
:thumbsup
Think your preaching to the converted on here.
Back to the OP, I heard the NIC prosecuted two for it last year. struck off and £20k fine.
Its only a £5k fine if Building control find out you did it yourself so I guess its going to go on for a while yet.
That's exactly what I would do as well. Did a little bit of work for a couple of London councils when I was over there, they where happy enough with a PIR. That said they would probably have been happy enough with a bit of toilet roll signed - they didn't seem to have much of a clue about anything!
Sorry but I Don't agree
Defects comes down to contractual arrangements
faults and problems is a bit wooly to say the least
Having worked in a test team for both CHT, BBESL and MJN couldsons it is not uncommon to test someone else's work and also i will stand by the fact that a test is only as good as the moment it is done!
What's the difference because once you do a eicr you've took the responsibilty for that report I would have no problem carrying out testing on some ones work if it all complys with bs7671 then there's no problem
I don't see how a company can issue an EIC for work that they haven't done. If checked at various stages throughout the job then fair enough, don't see that as all that likely though.
what happens say a company has done 80% of a job then goes under new contractor comes in and your saying they should then rip it all out and start again? no you certify it with limitations!
You can't put LIM on an EIC, you can on a EICR. Unless you are able to inspect under floorboards, in the walls etc then I'd not be signing no EIC. On an EICR it can be recorded that you couldn't inspect these.
Reply to what is the law on testing in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Recommended Sponsor News
thanks for the clarification. ( also thanks to Dan. ).
More info on link below http://sbsc.uk.net/
9K
Happy Friday Everyone! Subscribe for more jokes direct to your mailbox or send us your own jokes to be in with a chance of featuring, by clicking...
6K
