W
wannabesparky
i cant certify work at the moment so if i was to do a rewire say, what is my procedure?
who do i go to?
who do i go to?
Discuss what is the procedure if i want to do a rewire but cant certify my own work in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
A Part P Sparky.
ive read or heard it mentioned that i can go to building control or summat and inform them of the work and they come and check it, is this right? if so where is building control and what is the procedure?
You will need to contact the building control dept of the council in the borough in which the property is in. They will want to inspect the work at each stage of construction of the installation right from the start of the project. At the end you will have to test the installation and issue a Electrical Installation Certificate to both the client and the LABC.Of course there will be a LABC charge for all of this. Hope this helps.
Reply to what is the procedure if i want to do a rewire but cant certify my own work in the Electrician Courses : Electrical Quals area at ElectriciansForums.net
