What is the purpose of this. | on ElectriciansForums
Discuss What is the purpose of this. in the UK Electrical Forum area at ElectriciansForums.net
westward10
Staff member
Admin
Supporter
Northamptonshire
Was visiting the priory at Canons Ashby when I see several of these dotted around the building. A date at the top indicates 1982 so not part of the original building fabric. I know what they are but anyone else. The top has been cut off but it just ends at a bowl shaped affair.
[ElectriciansForums.net] What is the purpose of this.
Maybe there's no rainwater coming down them now... but I'm almost certain that's what the original purpose of them was. They were probably reinstated in 1982 so as to comply with listed building regs ? Can you go back there again and take another pic of the top part ? Also the bottom part too would be useful...
Anything to do with concealing lightning conductors
You are correct but they are not concealing a conductor they are the conductor. At the base, not shown is a test label and an electrode bolted to the bottom. It was difficult to tell but they could also be acting as downpipes but I am pretty sure they aren't as the top didn't appear to connect to anything else. I have seen decorative tops to protection systems but not these parts.
Was thinking they might be the actual conductor but dismissed it
There's my girlfriend looking at the gardens and me looking at lightning protection ?
It was the test notice that drew me to them because I just thought they were downpipes.
That roof looks to go down behind a parapet wall and the things at the top look like collectors/hoppers that will be draining the gully behind the parapet wall.
It is possible but the apparent collector has a dome on it but it could enter behind that. That aside the notice on them states they are lightning protection.
Could be that they are earthed as the present a risk of lightning hitting them rather than being installed specifically for that reason, or two birds with one stone.
Reply to What is the purpose of this. in the UK Electrical Forum area at ElectriciansForums.net
This is an RSS feed of thread: Hole in copper pipe, solder under floor, T coupling & protection Content of the thread: I was stupid enough not to...
