What Is This Device | on ElectriciansForums
Discuss What Is This Device in the Electrical Tools and Products area at ElectriciansForums.net
M
mhm
In the NIC Snags and solutions book (ISBN10- 0-95310589-x) on page
four there is a diagram of a single phase consumer unit instalation.
Going from right to left there is a DIN mounted master switch followed by two busbar terminals conected to each of the RCDS. I would like some of them but have absoluty no idea what there called?
Thanks,
Tom
It's not a RCBO.
It's effectivly a DIN mounted terminal block with the busbar going in the bottom and a screw down connection in the top.
Hager do an MCB profile 100A rated terminal block. (cat ref KR50U) just a way way of taking a supply straight off the busbar to a cable. Aint got the book but it sounds something like this!!!
Thanks,
Tom
Scan the image and post it on here so we can all have a guess:cool:
Thanks Steve, I'm Pretty sure this it it. I have ordered 10 and will let you know when they come down.
Tom
Reply to What Is This Device in the Electrical Tools and Products area at ElectriciansForums.net
Hi Richard, thanks for your comment. The relay is rated 12A peak. It's also worth noting that a relay contact will perform differently depending...
    • Winner
