What is wrong here? | on ElectriciansForums
Discuss What is wrong here? in the DIY Electrical Advice area at ElectriciansForums.net
Nino81
Oslo
Greatings from Norway.
I am trying to install an outlet and thought this setup would be correct. But it's not working.
Please advice
Nino
  • [ElectriciansForums.net] What is wrong here?
Reply to What is wrong here? in the DIY Electrical Advice area at ElectriciansForums.net
It could be a slave switch where you would have a L in and a common wire out to a master switch.
Thanks will give that a try in a little while Cheers Writing to say thank you very much for that advice, its worked! Really appreciate the help
