Fazz711
Hi .
I normally do industrial electric work.
Usually on Schneider and Merlin Gerin boards
I am looking at fitting a new consumer unit at home and seem to be getting two versions of which board would suit best.
Either a dule RCD board with MCBs
Or A board with all RCBOs.
Which would be best and why?
Rcbo board anytime,keeps faults separate and you don't need to worry about the 9ma leakage current limit on any 1 rcd. I only fit full rcbo boards with spd for single phase
Thanks.
Any recommendations on type.
I usually fit Schneider stuff and I can find one with the right RCBOs I need but will consider other if any are recommend as better.
Hager or Fusebox….. or whatever I get the best price on.
As explained above, all RCBO gives better separation of circuits the dual RCD, losing only one circuit instead of a bunch of them.
Possible nuisance trips are harder to diagnose.
Only downside is the increased initial cost.
What’s the physical location like for space to fit in a new board?
All mine seem to include destroying some well built cupboard surround, ;) :D
It lives above kitchen cupboard.
I was going to box it in when I fitted the kitchen but it didn't happen.
Glad now as plenty of room.
RCBOs can help with the space problem. Going from dual RCD to RCBOs releases four modules on the DIN rail, which may allow you to go down a size in enclosure.
That doesnt sound like its easily accessible for swapping out.
Be prepared to take the cupboard down to give you some more working space.
This is the space
I have eight RCDs and only use seven.
The Schneider one I think is 12 and comes with eight RCBOs and will cover what I need
You don't appear to be limited in space horizontally, as is often the case, so my comment isn't really applicable here.
Is that meter as your supplier left it?
A fusebox dp rcbo board is my goto one.
I always now use DP rcbos as in the case of an N To E fault sp ones won't clear the fault.
Especially recommended on TT that uses an upfront Rcd.
I like Schneider ones as that is what I have most experience of from years of industrial work.
Having looked at fusebox ones I am leaning that way.
Fazz711
High Peak
RCD or RCBO consumer unit
Fazz711,
Teddy Lop,
TrueNAS JBOD Storage Server
