What kind of resistor as there are so many? | Page 2 | on ElectriciansForums
Discuss What kind of resistor as there are so many? in the UK Electrical Forum area at ElectriciansForums.net
Camberley
Hello and thanks for taking
a look at my question.
Basically I am struggling to source some resitors that I need to connect into a circuit so my instrument can read realistic measurements on a small rig.
I need 1ohm, 2ohm, and some 0.5ohm, 0.2ohm and 0.1ohm resistors.
When I ring RS they say that they have thousands of different types and need more information.
When I type them sizes into eBay I'm left perplexed on what would be the right purchase
I've got some one who said they help me install them but I don't want to keep asking him stupid questions as I've already asked him what size resistors to get and was called needy ? so I don't want to push my luck.
If anyone knows what it is I need to be asking for would you mind telling me so I can order them please?
Thank you for any help
Cheers for dropping in @pc1966. Appreciate it.
Going on what you two have just said and the fact that I was told they are only cheap for packs of 10 I think it's either like you and @SparkyChick say, a through hole style one or the metal ones with solder lugs. Not that I new that before.
I'll ring RS back armed with that new information.
Thanks alot you two ?
Wire them via a bank of grid switches so you can easily switch them in and out
I asked Megger at Dover about the currents which circulated when one of their MFT's is used. A very helpful reply which I can summarise as:
1. To comply with BS7671 the current is at least 200mA during continuity tests;
2. During high voltage insulation tests the current is about 1mA;
3. During two-wire high current loop tests the current is about 20A in older MFTs and about 5A for newer models - these tests only last milli-seconds so the Ohmic heating (IsquaredR) in any test resistor will be negligible.
The resistor power ratings I have recommended will therefore be suitable.
Reply to What kind of resistor as there are so many? in the UK Electrical Forum area at ElectriciansForums.net
Just doing some thread admin :)
