what light switch is this? | on ElectriciansForums
Discuss what light switch is this? in the UK Electrical Forum area at ElectriciansForums.net
B
beesley121
Hi guys,
can you please tell me what this type of switch is called as im looking for a replacement in the screwfix catalogue and cant find one
http://www.flickr.com/photos/39955962@N08/7494356112/in/photostream
i think is a 2 way, 4 gang switch (has 2 seperate switches on the front. 4 ports on each switch at the back)
its a stainless steel switch with a white insert.
if anyone would be kind enough to point me in the direction of an alternative, i would reall appreciate it
The light switch in the picture is a two gang two way.
The fourth hole next to the common is redundant. Either a two gang two way switch or a two gang intermediate switch would do the job. The former would be the cheapest option however.
Reply to what light switch is this? in the UK Electrical Forum area at ElectriciansForums.net
As above you will probably find the originals where oriented the same way and your replacements are upside down to each other, or visa versa. I...
