Hi guys got my final board done before half term, forgot to complete my material list, can anyone help with what else goes on here? Thanks
TL;DR
what goes on the material list for task 204 Lvl 2 (2365) final board.
If you fill out most of it, we should be able to help fill in the gaps.
Upvote 0
We are not a homework completion service.
Make your best effort and we will guide you to the correct solution.
Upvote 0
If it isn't that deep then itemise what parts you have used, we don't know as we didn't do it.
Upvote 0
By all means, wrote down what was used, and we can help with the more “technical” names of things…. But as mentioned, we don’t know what was put in.
If there was 50x50 trunking…. Did you use singles? That would possibly be 6491X cable, in various colours.
Was there also conduit used? Steel? PVC?… couplings and bushes? 20mm, 25mm?
Upvote 0
Hounslow, Greater London
United Kingdom
Trainee Electrician
What needs to be filled out on the material list - 204 level 2 (2365)
Electrician Courses : Electrical Quals
Thread Tags
Tags Tags
None
esa1211,
littlespark,
Electrical Courses
